Fuel cuts out at 5500 RPM, right when VTEC is about to hit, wtf?
just droped another d16y8 in and now when i get to 5500 rpm the fuel cuts out. What are something that could be stopping this. Everything VTEC related is connected.
Re: Fuel cuts out at 5500 RPM, right when VTEC is about to hit, wtf? (sol2hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sol2hatch »</TD></TR><TR><TD CLASS="quote">Sounds like your in Limp mode, are you throwing any codes?</TD></TR></TABLE>
P0453
P0420
those were the one i was usually getting since i dont have a cat and my car is a 97 HB so it didnt come with a Fuel Tank Pressure Sensor
P0453
P0420
Re: Fuel cuts out at 5500 RPM, right when VTEC is about to hit, wtf? (turbociviccoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbociviccoupe »</TD></TR><TR><TD CLASS="quote">try a different ecu and check the tps sensor to see if its adjusted right</TD></TR></TABLE>
TPS is good cuz i replaced that before i put the motor in.
im going to use the shops OBD 2 reader today to check and clear the codes and then ill see how it goes.
One thing is last night i checked under the hood and my VTEC Selinoid wasnt connected, then i connected it up but i did not clear the ECU. could this be a reason?
Re: (Sivic2000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sivic2000 »</TD></TR><TR><TD CLASS="quote">did you reset after you connected to vtec selinoid?</TD></TR></TABLE>
nope, i want to check the codes before i clear it.
Re: (pumpkyn)
My car did this. It ended being the ignition coil in the distributor was going out. So anytime I would put any load on it (vtec) it would act like the fuel cut off was kicking in or it would completely die.
As long as I dont have to take out any more Metal Gears
Re: Fuel cuts out at 5500 RPM, right when VTEC is about to hit, wtf? (pumpkyn)
have you checked your oil level lately?
Re: Fuel cuts out at 5500 RPM, right when VTEC is about to hit, wtf? (rukawa1one)
yeah its level, but i did find a split in my valve cover gasket, could that little bit cause that?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pumpkyn »</TD></TR><TR><TD CLASS="quote">yeah its level, but i did find a split in my valve cover gasket, could that little bit cause that?</TD></TR></TABLE>
No
No
Re: (pumpkyn)
+1 for limp mode. Get a cat in there and you can wire up something to "trick" the ecu into thinking the ftps is working. http://technet.ff-squad.com/code91.htm <- this site tells you how to wire the thing. Or, just convert to OBD1
Re: (wakeboard_dude5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wakeboard_dude5 »</TD></TR><TR><TD CLASS="quote">+1 for limp mode. Get a cat in there and you can wire up something to "trick" the ecu into thinking the ftps is working. http://technet.ff-squad.com/code91.htm <- this site tells you how to wire the thing. Or, just convert to OBD1</TD></TR></TABLE>
well the thing is before the last engine went down i didnt have a cat or ftps and it reved to 7k no problem.
K, got it checked again and i am getting P1259 So i guess ill clean out the VTEC Silenoid first, becasue before the engine went down we used some thick thick oil to help keep the car from smoking.
cleaned out the solenoid and nothing, and since i did a mini me i changed teh ground of the oil pressure switch and now i can rev all the way, but no VTEC now. Tomorrow i am going to check the solenoid itself so see if it is even working
