Tranny HELP PLEASE!! Tranny fluid???
i have a stock Ek with a EF7/ETF ( which ever it is )
a Tranny mechanic told me im low on Tranny fluid just by listening to my gears
ive never worked on a transmission
Where do i out the fluid? oil? i used to think only automatic trannies need fluid >.<
but can someone show me a picture where to add some fluid?
and what kind of fluid please!!
Where and what kind of fluid to add to my Tranny?
thank you!
thank you!
Re: Tranny HELP PLEASE!! Tranny fluid??? (Black Cloud EG)
I'm not sure how he can tell the fluid level just by listening but ok. There will be a drain plug and a fill plug on the side of the tranny. The fill plug is the one on top. If you just want to top it off, remove this plug and fill with MTF till it drips out (use a long hose on the end of a funnel). I you want to drain and refill, you can remove the bottom bolt, let it drain out, put it back in (use a new washer) and fill.
Re: Tranny HELP PLEASE!! Tranny fluid??? (nonsense)
i cant really tell where the side of the tranny picture is
if im looking at my engine bay fro nthe front
it should be on my left hand side by the passenger side fender right?
Re: (EK 2.0)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EK 2.0 »</TD></TR><TR><TD CLASS="quote">and if you are gonna drain and fill...make sure you can remove your fill plug BEFORE you remove your drain plug...</TD></TR></TABLE>
Even if you can't you could go in through the VSS.
pelotudo
07-21-2002 02:33 AM
