clutch problems
clutch problems
so i got my d15b in my cx hatch. everything was perfect for the first week untill i noticed the clutch felt weird. it wouldnt engage and disengage untill thr clutch was almost to the floor. the pedal pressure seemed to be weird also...so i bled the system again and re-filled the line with fresh fluid...now the clutch hardly works at all when the car is running. and it makes a god aweful sound when the clutch pedal comes out.
i noticed i was leaking fluid out the clutch cylinder boot...is there some sort of clamp on the black boot to hold it on there more secure?
im hoping it just has to do with the clutch hydrolic system and not the clutch.
any ideas would be appreciated
Re: clutch problems (integraca)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integraca »</TD></TR><TR><TD CLASS="quote">
any ideas would be appreciated </TD></TR></TABLE>
It sounds like you have a bad clutch cylinder if you are singin fluid on that boot. Replace it and reblead the system but I wouldn't be supprised if you don't need a clutch also. Esp if you did a motor sway and didn't change the clutch then
Jdmkolb89
Honda Civic (2001 - 2005)
08-03-2012 10:10 PM
s13hero
14
11-21-2010 04:57 PM
geminis2k
11-20-2003 11:33 AM
