1.6 EL tie rod ends
1.6 EL tie rod ends
I need to replace my inner and outer tie rod ends on my 1997 1.6 EL.
I found something on this forum about replacing the rod ends on a 00 ITR.
Will the procedure be more or less the exact same on both of these cars or is there a major difference for an EL.
Also is it acceptable to use the same generation Civic rod ends or is the acura steering somehow different?
thanks a lot!!!
thanks a lot!!!
Re: 1.6 EL tie rod ends (marks97el)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by marks97el »</TD></TR><TR><TD CLASS="quote">I need to replace my inner and outer tie rod ends on my 1997 1.6 EL.
thanks a lot!!!</TD></TR></TABLE>
i'm 90% sure the tie rod ends are the same....and integra TRE's and civic TRE's are verry simmilar so it should be the same procedure...GL....bump for CANADA!
Former Moderator
Procedure is the same for both cars.
Parts for the 96-00 Civic 4 door should be the same as they are for an Acura EL, but you can always call a Honda and Acura dealership and compare the part numbers from each dealership and then buy them from whomever is cheaper.
Re: 1.6 EL tie rod ends (B18C5-EH2)
was wondering if you knew weather you should swap in tegra tie rod ends to a civic if you are putting tegra brakes/suspension conversion over to the civic?
SlammedBlueEM2
08-04-2004 04:45 PM
TodaCivic
06-09-2004 02:25 PM
