Beaks subrame prace + 18mm swaybar.
I have a 97 ex. Would a beaks reniforcement bar be alright with the smaller 18mm cusco rear swaybar? I have heard that these are no good with the ctr rear sway bar and soft spring, but wat about the small cusco? BTW i have tein s techs.
Re: Beaks subrame prace + 18mm swaybar. (turnsignalandy)
I would assume it'd be fine. I used a beaks kit with a 21mm blox bar on my eg and never had any problems. with the EK having a weaker subframe and you'll be using a smaller bar, I'll say you should be fine.
Re: Beaks subrame prace + 18mm swaybar. (broketuner-sol_si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by broketuner-sol_si »</TD></TR><TR><TD CLASS="quote">I would assume it'd be fine. I used a beaks kit with a 21mm blox bar on my eg and never had any problems. with the EK having a weaker subframe and you'll be using a smaller bar, I'll say you should be fine.</TD></TR></TABLE>
why take the chance? if you are unsure, which it sounds like you are. then go with a product you know it's not going to fail. granted the beaks is cheaper, but cheaper isn't always better. not to mention, if the beaks brace fails, now you'll be paying more to repair it than buying a asr or comptech brace.
Pfieff
19
10-22-2003 12:05 PM
