another teg dash swap question...I DID SEARCH
I am trying to do a dash swap in my EG hatch. I have a 94 harness and all the other stuff, but I think I have a OBD 2 gauge cluster because it has black gauges not grey. I read litterboxes FAQ and it doesn't really say what one you need. Now I used his method of just using the integra harness and cutting off the grey plug off the civic harness. Basically, the only thing that worked was the blinkers...nothing else. So can someone help me out here please...and once again...I have seriously spent hours searching
Re: another teg dash swap question...I DID SEARCH (shoebox)
teg's blue left side plug (13 pins)
1.blu-tach signal
2.grn/org-check engine indicator
3.yel/red-oil pressure switch
4.-
5.wht/blu-charge indicator
6.-
7.yel/grn-coolant temp
8.blk-ground
9.red/blu-cruise (if you have cruise)
10.yel-hot
11.-
12.pink-maintenance (not used)
13.-
teg's right side blue plug (16 pins)
1.grn/red-e.brake signal
2.red/grn-high beam
3.grn/yel-right turn
4.grn/blu-left turn
5.-
6.blk/yel-power
7.red/blk-power
8.red-power
9.blu/red-abs (not used)
10.grn-trunk switch
11.org-vehicle speed sensor
12.-
13.blu/wht-low fuel (not used)
14.yel/wht-fuel gauge
15.lt grn/red-door switch (not used)
16.red/blu-seat belt
civic's left side grey plug (12 pins)
1.yel/wht-fuel gauge
2.yel/blu-vehicle speed sensor
4.grn/blu-left turn
5.wht/blu-charge
6.yel/red-oil pressure switch
7.-
8.blu-tach signal
9.-
10.blk/yel-power
11.red/blk-power
12.red-power
civic's right side grey plug (10 pins)
1.red/grn-high beam indicator
2.grn/red-e brake signal
3.-
4.-
5.grn/org-check engine indicator
6.blk-ground
8.yel-hot
9.grn-trunk switch
10.blu/wht-seat belt
this is what i used to wire mine, works fine
good luck
1.blu-tach signal
4.-
6.-
8.blk-ground
10.yel-hot
11.-
13.-
2.red/grn-high beam
4.grn/blu-left turn
5.-
6.blk/yel-power
7.red/blk-power
8.red-power
10.grn-trunk switch
12.-
4.grn/blu-left turn
5.wht/blu-charge
7.-
8.blu-tach signal
9.-
10.blk/yel-power
11.red/blk-power
12.red-power
3.-
4.-
6.blk-ground
8.yel-hot
9.grn-trunk switch
good luck
Re: another teg dash swap question...I DID SEARCH (kevmugen)
I don't really know how to read these diagrams, and I would like to just use the integra harness and switch the grey plug that goes into the fuse box...
i just wired mine at the cluster and it works fine, cant help you with the fusebow part sorry... good luck again
litterbox
03-02-2005 12:11 PM
Midwest Auto Salon
09-15-2004 08:27 PM
Dancing is Forbidden
10-04-2003 09:56 AM
