Questions about integra rear suspention swaps.
so after doing an alignment on my car at school, i found out that my rear suspention is tweaked. i ended up with the left toe maxed out (negative) and only got it to .7 degrees positive and tryed to counter act it with the right maxed positive to the opposite max and only got it to .3 degrees. after finding that out and searching i found this (https://honda-tech.com/zerothread?id=641639). i thought ****, why not upgrade while fixing my car, only problem is sence im on a college budget, i might try something to fix it for the time being and found megan racing toe kits for 65 bucks. im just wondering if i can use this with the teg suspention sence ill be using the teg trailing arms. also it doesnt say anything about lower control arms, im guessing ill be using the civics. my car is a 97 ex coupe.
