B series Brackets and T bracket question
I have a 99 Ex coupe Sunroof model , Im doing a B20b swap It has a D16Y7 Instead of the D16Y8 . Would Those Brackets and T Bracket work or would it not line up? Thanks! daniel-
Re: B series Brackets and T bracket question
Driver's side mount works if you bolt a '99-00 Civic Si 2-bolt bracket to the driver's side of the block (under the timing cover), transmission mount and bracket work fine if the car is a 5-speed, the rear mount works but you will need to replace the "T" bracket with one from a '99-00 Civic Si. If you want the front torque mounts, you will need a '94-01 Integra transmission torque mount bracket (you can use the Civic frame rail mount) and the A/C bracket from a '97-01 CR-V or a '94-97 Del Sol VTEC (and again, you can use the Civic frame rail mount). Your stock A/C compressor will bolt to this A/C bracket if you choose to keep it.
mnskateboarder
04-12-2008 11:34 PM
XkjeldorX
06-21-2006 01:49 PM
