Question my B20B people.
99 Civic ex Sunroof model . I picked up a 99-01 B20b from a shop and I ordered a Aem fuel rail with Fuel lines and regulator kit from JBtuned.com, Would the Injectors that came on The b20 Intake manifold work on a Ls Intake manifold since its a Aem Fuel rail not the Ls Fuel rail or No ? Im also getting the hondata V3 Ecu , Just need B series wiring harness and axels . Anything eles ? Im going to the junkyard to get the Brackets and if I cant find em Ill order em. Im going Ls Transmission since no shops have Gsr or b16 transmission in my city.
Re: Question my B20B people.
You have posted THREE separate threads with varying questions... it is likely better to ask multiple questions in a single thread for the sake of continuity. The fuel injectors will work just fine... although the O-rings may be really tight in the AEM fuel rail. You will use the '99 Civic EX engine harness and modify it to fit on the B20B engine. You will need a set of Integra shift linkage and axles (with a midshaft if your engine/trans doesn't have it).
