Confirm if this is the thermostat bypass hose
Old 07-10-2018, 07:42 PM
Curlybandit's Avatar
Default Confirm if this is the thermostat bypass hose
Hey everyone.
I have a '93 del Sol Si with a JDM GSR swap. I noticed a subtle smell of coolant in the cab when driving. When I looked under the hood I saw a tiny spray of coolant coming from pin-hole in the small hose that attaches from the thermostat housing to the passenger side of the intake manifold (using a Skunk2 GSR IM) where it mounts to the head. I believe that it's called the thermostat bypass hose.
Can anyone confirm this? I've attached a picture.
Thanks!
Old 07-12-2018, 09:43 PM
JRCivic1's Avatar
Default Re: Confirm if this is the thermostat bypass hose
The bypass hose is the larger 5/8" L shaped hose in your photo. The smaller 5/16" coolant hose is part of the T/B and IACV de-icing circuit. This small port on the Skunk2 I/M just below the bypass fitting can be un-necessary in some applications, so you will have to examine what you have and how the circuit is run.
Old 07-22-2018, 06:42 AM
I can confirm that it is the thermostat bypass hose.
Went to the dealership and ordered the part: 19508-P72-000
I installed it yesterday.
zx92027xz
19
01-15-2014 04:36 AM
93 del sol si2
07-12-2013 04:21 AM
crxb20ed
01-05-2005 12:22 PM
Quick Reply: Confirm if this is the thermostat bypass hose
