Engine wont turn by hand with transmission bolted all the way in
Hello everyone, I’m currently having an issue with my engine after swapping out my blown d16y8 with a 100k mile d16y8. My issue is that the engine does not want to turn if i have the transmission all the way bolted in. If i back off the bolts a bit then it rotates fine. Also, i turned the shaft in the transmission by hand and there was nothing wrong with it. When i crank it i hear a noise of something hitting something else as well. Can anyone help me with this? Much appreciated.
Re: Engine wont turn by hand with transmission bolted all the way in
Don't start new threads about the same problem.
You also never in either thread said if the car is manual or automatic, that is part of the posting rules.
Manual transmission. If it helps, the engine was previously in an automatic. While it is the same issue, I’ve figured out that its something when the transmission is bolted in all the way, my old post was getting no attention so I thiught to make another thread.
The noise is kind of hard to pinpoint, but its coming from somewhere in the transmission. I might have accodentally used auto bolts when reassembling, Ill check it out when I have a day off.
Can you elaborate? As in shift it with my hand or something? I will definitely do this when I can.
I also just checked my extra set if flywheel bolts, on the top of the bolt it says AT. This means that those are the ones to the automatic flex plate yes? If so then I guess thats not my problem.
So I did all you said to do, transmission seems fine. I also removed my clutch and flywheel and just reinstalled it again, reapplying threadlocker as well. I think i might have found my issue though. These pins on my new pressure plate look like they stick out a little bit further than the ones on my old pressure plate. They look damaged from hitting something when they didnt look like that when I first got the pressure plate. Ill put in some pictures so you guys can see what im talking about.
So I think I have to shave that metal pin in the first two pictures down to fix this.
That part screws into the transmission. Use an 8 mm hex key to make sure it is tight.
If the thrust bearing in the engine is bad, the crankshaft can move end to end. But really it looks like that ebay clutch cover isn't quite in spec.
Masterbobo
Honda Insight & CR-Z Hybrid
02-22-2011 09:26 PM
