New Member 94 civic 1.5 l mil dtc 8 HELP
Failed smog
check ignition timing mil/cel dtc 8
OBD systems check
Fuel Evap controls function
The vehicle failed the OBD system check because the MIL was on
Please advise
OBD systems check
Please advise
Re: New Member 94 civic 1.5 l mil dtc 8 HELP
Check your distributor wiring... all plugs/pins pushed in tight and no broken or frayed wires. If all appears good... replace the distributor housing.
I replaced the distributor already due to the bearing being bad and new cap/rotor plus wires.
Wiring is all good and connections as well
rhdjdmda6
07-13-2006 04:52 AM
civicboisi
10-04-2004 08:27 AM
