Mechanical problems
Mechanical problems
So lately My car has not been wanting to start. When I crank it the battery light flashes or sometimes it’ll start then shut off , One of the cables that connects to the terminal is cracked but It has always started right up , Never had the problem of it not starting till now. I try to use a scanner but It doesn’t communicate. I checked fuses and main relay everythings good. Could it possibly be my Ecu or wiring harness ? Im using a wiring harness that has vtec and my car doesnt have vtec so that connector is unplugged
Re: Mechanical problems
What is the year, model, and trim level of the car in question? Wiring harness, too.
The battery light is actually a charge warning indicator light. It only illuminates if the charging voltage is too low. It will not reliably turn off if the car is not running since the alternator isn't spinning fast enough, so disregard that for now. What terminal? Bad battery wiring is a red flag. Those need to be repaired.
Engine scanner (if 96-2000) not connecting is typical of a blown fuse. Need to know the year of the car and engine/harness/ecu to assist further. 88-95 systems blink long/short red lights under the passenger carpet if triggered a certain way, pending model year.
Well, you need air, spark, compression, and fuel. Time to figure out what isn't working. How did you test the integrity of the main relay? Starting and stalling is an extremely common failure mode of the main relay.
How did you check the fuses? Visually or with a multimeter set to continuity? Hairline cracks can be deceiving.
Why would it be the ECU or wiring harness if it suddenly started to fail? Something changed or failed, and it's time to target the easiest/common stuff first.
I would inspect distributor cap/rotor, spark plugs, resistance test the wires/coil/ignitor, ACTUALLY check for (blue/white) spark, and fuel, then go from there. Tell us what you find. I honestly keep 1-2 extra main relays in my Hondas since they're super common to fail. Haven't had to use them yet but you never know
Bbasso
02-14-2008 11:20 PM
baastard
05-25-2006 07:52 PM
civiclxb16a
04-22-2005 05:14 PM
neiloneil03
09-14-2002 04:28 PM
