No vtec, new swap
No vtec, new swap
We just did h22 swap for my brother civic. It has 5 speed with p28 chipped ecu/h22 basemap. We started the car and let it idle until fully warm up. Then we took it for a run but no vtec!!! I made sure that everything is ok. We have oil pressure because i installed an oil pressure gauge. Oil level is ok, no leaks and no cels. i connected A4 to D6 but nothing. I tested the continuity of the solenoid with ground it has continuity. Then i ran a wire from the battery,another wire from the solenoid and let my brother touch them together at 5500rpm and vtec worked. Does that lead to a bad ecu??
Re: No vtec, new swap
Why would you connect A4 to D6 ??? A4 is the single wire for the VTEC solenoid. D6 goes to one of the two wires at the VTEC pressure switch... the other wire from that plug goes to the ground at the thermostat housing. If your wiring is clean and proper as suggested above, you either have a bad ECU or a bad chip/program. It never hurts to try a known good ECU just once to see if VTEC will "pop".
i already checked it and I try to run new wire from the solenoid to the ecu. I also checked the continuity
Possibly another sensor that is faulty or not getting the proper signal to ecu. There are parameters for TPS, VSS, ECT, RPM etc that must be met for it to engage vtec.
Just wanna let you know guy problem solved because of the missing Q26 Transistor. So if anyone encounter any issue with vtec and he checked oil,vtec related sensor ect, vps and vtec soleniod you have to check all the vtec components at the ecu board.
So, your problem turned out to be a failure in the VTEC conversion process of your P06 ECU by whoever was tasked to solder in the required components to your board.
ECU is P28. The guy how chipped it moved Q26 to Q28 not sure why but after searching online i found that the correct place for the vtec transistor D1423 is Q26 for the 1720 boards.
kaoss_11
04-14-2007 07:18 AM
