can you show me a diagram of how coolant flows through my 1997 honda civic hx
I am not complaining.....but I am a 60 year old female at the mercy of those people I am asking for help. May I please get a diagram of how coolant flows through my vehicle and where I should check for clogs. Please
Re: can you show me a diagram of how coolant flows through my 1997 honda civic hx
The major flow path is from the bottom of the radiator, through the lower hose, through the thermostat, across the metal pipe on the back of the engine, through the water pump, through the engine (block and head), out to the top hose, then into the top of the radiator.
The only parts that can really get "clogged" are the radiator and the thermostat. Technically the thermostat isn't clogged, but it can be stuck closed which causes overheating.
Has a "stop leak" compound ever been used in the car?
Also don't forget about the water valve that lets coolant into the heater core and the outflow from the heater core back into the block (usually just past the thermostat).
Why do you think it's clogged? If it's because you have no heat, you prob have a leak somewhere and have air in the system. If it's a slow leak that's been going on for a long time, you could just top off the coolant and bleed the system as a temporary bandage. Or Like jonsey said the water valve is the issue. I've see soo many where the valve isn't moving where if your real lucky you can just tighten the screw on the valve arm.
Hot water rises. Cold water falls. Engineers of the Civic and every other car knew this. Flow through a radiator is always top to bottom so as to not fight this law of physics.
So, to prove your theory... how about performing a test by removing the lower radiator hose from the thermostat housing and hold that end up high in the air... remove the thermostat and install another hose on the thermostat housing and raise it up into the air... both being higher than the valve cover. Next, fill both hoses with water making sure that no air is trapped in the system. Finally, crank the car. If the fluid pathway is as you stated, the water in the hose on the thermostat housing will be sucked down and the water in the hose attached to the lower fitting on the radiator will be pushed out. On the other hand, if the fluid pathway is how I have explained... the water will come out of the hose on the thermostat housing instead of the one attached to the radiator.
Another helpful detail: Have you examined the blades on the water pump itself to get an idea of the water flow direction ???
OP, you can perform this test on your own as well and then you will be SURE of the fluid path yourself.
SeanK325
06-22-2010 02:52 PM
