Changing timing belt... What other maintenance should I do while I'm down there?
Changing timing belt 93 civic.. What other maintenance to do while I'm down there?
Doing a timing belt job soon. I'm at 150,000. Is there anything else I should do or check out since I'm removing the valve cover? Oil seals or anything?
1993 Honda Civic VX Hatchback D15Z1 1.5L
Re: Changing timing belt... What other maintenance should I do while I'm down there?
What vehicle?
O.G. triple O.G.
timing belt
water pump
front main seal (oil pump seal)
accessory belts
thermostat
cam seal
valve cover gasket
spark plug oil seals
spark plugs
water pump
accessory belts
thermostat
cam seal
valve cover gasket
spark plugs
The reason I asked what vehicle, some have oil coolers and some do not behind the oil filter.
Also want to check to see if this thread belongs in this forum.
O.G. triple O.G.
awesome thank you guys so much i just ordered some more parts.
couple more questions.
Which coolant should I use?
I'm also looking for rear trailing arm bushings but cant find them on oem part sites. what should company should i replace it with? looking for close to oem
I'm blind.
Are you in the USA, Canada, some other country? I ask as some fluids available to me in Canada may not be available to people in USA and vice versa (ask me how I know. )
Use OEM coolant from the dealer. I didn’t but am going to due to Tony’s recommendation.
In Canada we have a brand called OEM that allegedly is formulated to the same spec as dealer, they provide for each of the major manufacturers. We also have store brands that are for the specific model/type.
I'm not sure if you have the same availability in the states.
http://www.canadiantire.ca/en/pdp/oe...-0293080p.html
http://www.canadiantire.ca/en/pdp/mo...-0293070p.html
O.G. triple O.G.
coolant from local auto parts store will be fine. I would stay away from 50/50 type because who's to say the content is actually half coolant and half water. I usually get 100% coolant and get a gallon of distilled water.
Everyone has a thing. I used that mix with any color stuff...
