What injectors are these?
New injectors. Obd1? Or what?
My stock obd2 injectors
I know nothing about injectors. I acquired these in a bundle a while back and have lost all contact with the guy I bought it from. I know they are 1000CCs but I don’t know what brand. All the other parts in this bundle were quality name brand (not Ebay) so I’m hoping these are not as well. Anyway, I need to know what kind of clip I should use. I want to say they are obd1 injectors but I’m getting more and more confused at all the pictures I look at of obd1 injectors.
Re: What injectors are these?
They look like early Precision injectors... and if they are in fact 1000cc injectors, chances are good that they are low impedance (about 2 ohm) and will require an injector resistor box or individual resistors to keep from damaging the ECU. The plug style you have pictured is OBD-0 style which supports the probability of low ohm style injectors as well. Get a multi-meter and test those injectors... if they are greater than 10 ohms, you are good. If they are 2-3 ohm, you will need a resistor box.
