Condenser fuse blown in fuse box under hood
Old 04-17-2009, 09:35 PM
kaotikvizion's Avatar
Default Condenser fuse blown in fuse box under hood
When I bought this car like a year ago the A/C didnt work. if I change this fuse will it turn my A/C back on?
Old 04-17-2009, 10:03 PM
Former User's Avatar
Default Re: Condenser fuse blown in fuse box under hood
If the fuse is blown, replace it and go from there.
Old 04-23-2009, 08:24 PM
changed fuse and air aint cold whats the next thing I should do? I bought one of those recharge bottles with the gauge at auto zone followed the directions to a 'T' hooked it up to the L side & as soon as I started to spray the can the gauge went straight to red...???? what should I do next?
Old 04-23-2009, 08:29 PM
Before adding refrigerant to an A/C system, you need to obtain a proper manifold gauge set and measure the refrigerant pressure on the low and high sides with the A/C running. It's possible that your system dis not need refrigerant and that the problem lies elsewhere.
When you push the A/C button, does the condenser fan run and does the compressor clutch engage?
Old 04-23-2009, 08:37 PM
where can I get one of those manifold gauges? can I do it myself or do I need to take it to someone? the fan does turn how do I know if the clutch turns on?
Old 04-23-2009, 08:42 PM
Master Detailer
98civdx's Avatar
the belt on the ac pump free wheels off the motor intell you turn it on and it ingauges.
im 90% sure thats what he is talking about.
Old 04-23-2009, 08:45 PM
Using manifold gauges is pretty straight forward. You may be able to rent a set from your local auto parts store. If not, a reasonable set may cost from $50-$80. If you decide to go the DIY route, I can tell you what the proper pressure should be on the low and high sides.
When you push the A/C button, you should hear the compressor make a click sound when the clutch engages, and the engine should idle up to compensate for the increased load.
Old 04-24-2009, 10:43 PM
yeah nothing like that happens when the A/C buttin is on so what do I do now?
Old 04-24-2009, 10:56 PM
XKINGX's Avatar
it could be a number of things but but it sounds like your compressor coil is shot and or the compressor is locked up. more times then not when the compressor locks the coil is still engaged trying to turn the compressor burning the coil up then blowing the fuse. I rebuild compressors so if u want to see about me rebuilding yours pm me please.
josh beers
Honda CR-V & Element
07-25-2018 03:07 PM
American Import
29
06-08-2014 04:42 PM
jc2801
09-21-2009 05:18 PM
JettCRX
07-09-2006 07:52 AM
Quick Reply: Condenser fuse blown in fuse box under hood
