Timing belt still too loose
just replaced by block on the stock motor
d16y7
everything is on point but the block i got doesn't have the sensor the comes out from behind the crank pully... what is that for anyway?
and i tightened the tensioner all the way down... but the belt is still way loose.... what dose that mean? and how can i fix it?
d16y7
Re: Timing belt still too loose
lol... tightening the tensioner isn't the only thing you have to do.
With the tensioner loose and the belt installed, temporarily put the crank pulley bolt in the end of the crankshaft and tighten it down a little bit (no need to tighten really tight). Then turn the crank counterclockwise (with a 17mm socket, a ratchet, and the crank pulley bolt) so that the cam gear moves 3 teeth. Then tighten the tensioner's bolt. You should now have the appropriate tension. Then remove the crank pulley bolt and continue with normal reinstallation of the parts.
is that sensor Necessary? or can it be by passed... because it was on the block i pulled out, but not on the one i put in...
Are the new block and the stock block both D16Y7's?
so you already have the crank pulley on and you're tensioning the belt?
didn't you already replace the timing belt and didn't you already have to remove the crankshaft bolt?
get a crank pulley holder tool and a breaker bar. then crank on the bolt with another breaker bar, an extension, and a jack stand (for stabilization of the extension so you can focus all of your strength to loosening the bolt).
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/tdc-marks-crank-pulley-2533410/
^timing marks on crank pulley^
Like Trustdestruction said you can get the Honda crank pulley holder and use it if the Y7 pulley has the octagon shape cutout in the pulley.
I bought the tool years ago and have used it quite a few times. Another thing I have done and some might advise against this but I have never had any problems..you just don't want to get it to hot. Take a propane torch that you can get at Lowes,Advanced auto,etc and hit the end of the crank pulley bolt for a few seconds..this will heat the bolt up and make it stretch..then use your favorite impact gun on it. Mine is a 1/2" Drive air gun. I have taken off the Honda bolts using this method as well as the crank bolt on a Mitsubishi Mirage 1.8L.
Good Luck.
Good Luck.
Maybe not, but it will be a trick trying to get it out, and then not having the belt come off the crank sprocket, and then getting the tensioner back in and routed with the belt properly, and getting the spring off the tensioner.... I dunno, it guess its possible, but it will be a PITA.
It'll make it much easier if you can take the pulley off, there's just more space to work with. And if you drop anything, you'll have to take it off anyways
