b20 del sol
b20 del sol
i am doing a swap in my del sol i was wondering what i should do with it ....should i do the b20 or a b20 vtec and what would be best for boost
Re: b20 del sol
if you plan on boosting a b20 whether its b20 or b20v you should built it and sleeve it. the b20 block has thin cylinder walls and is known for blowing easily. if your going to do a b20 swap regardless i would throw a vtec head on it to make more power.
Re: b20 del sol
i beat them with my single cam all day i know it comes down to driver to but damn all i have in my single cam right now is light weight crank pulley,header,full exhust with high flow cat,cold air,8ilb fly wheel, stage 2 clutch,chipped p28 and a short shifter
Re: b20 del sol
as for the b20 your going to have to build it to make it more reliable. 7-8lbs tops with a t3/t4 setup is all i would run to keep it together.
Re: b20 del sol
well i only wanted to put like 8 pounds could i run that safely ...but on the bs factor i swear i beat them all the time i mean i had it in my hatch and i traded for the del sol and my hatch was gutted
Re: b20 del sol
8 pounds would be fairly safe, but it all depends on the tune as well. if it is spot on you should be good to go. i wouldnt try for much more then that though.
Re: b20 del sol
yeah everyone was telling me i need a block gaurd but i heard the same thing what would be the best to keep the block together ...i plan i doing pistons and rods and apr rod bolts
Re: b20 del sol
do you plan on running forged internals? if you do you might as well sleeve the block too so you can run higher boost and get the full potential out of your motor.
