identifying my motor - help
Re: identifying my motor - help
I dont think its a jdm motor being that it has a number after the b18c indicating where the block was originally made.. For example the b18c5 where 5 indicates that it was made in the U.S.. same for the b18c1 where 1 indicates that it was also made in the U.S but for the GS-R model..
I believe the b18c3 is from Poland. the #3 indicates its from Poland
All Jdm motors will NOT have a number after the engine code.. so a type R motor will be b18c
wrong....
all vtec motors will have the word VTEC on the valve cover besides some single cam vtec.. so the h22a is vtec meaning it has a vtec on the valve cover
therefore, according to your sentence, the ls is the only one without the vtec on the valve cover
wrong.... b18c5 and b18c are slightly different type R motors..
B18C (Type R)
* VTEC
* Found in:
o JDM Honda Integra Type R
+ Power: 205 hp (153 kW) @ 8500 rpm
+ Rev-limit: 8,900 rpm
+ VTEC engagement@5,800 rpm
+ 137 ft·lbf (186 N·m) @ 4200 rpm
+ Transmission Type: 5-speed standard with LSD
+ Displacement: 1,797 cc (109.7 cu in)
+ Compression:y 11:0:1
+ Bore: 81 mm (3.189 in)
+ Stroke: 87.2 mm (3.433 in)
+ Rod Length: 137.9 mm (5.429 in)
+ Rod/Stroke Ratio: 1.58
+ Transmission: J4D (96specR w/ LSD)N3E (98specR w/LSD)
B18C5
* VTEC
* Found in: USDM DC2 Acura Integra Type-R (Integra Type-R)
o 1997-2001 Integra Type-R (**Note: This model was not produced for the 1999 production year)
* Displacement: 1,797 cc (109.7 cu in)
* Compression: 10.6:1
* Bore: 81 mm (3.189 in)
* Stroke: 87.2 mm (3.433 in)
* Rod Length: 137.9 mm (5.429 in)
* Rod/Stroke Ratio: 1.58
* Power: 195 hp (145 kW) @ 8200 rpm & 130 ft·lbf (180 N·m) @ 7500 rpm
* Transmission: S80 w/LSD
* Vtec engagement @ 6,000 rpm
wrong....
B18C (Type R)
* VTEC
* Found in:
B18C5
* VTEC
Yeah in the ones actually from Japan they are all stamped b18c
According to wikipedia the C3 is from ITR in Taiwan and Hong Kong and in the Civic VTi.
oneprelude
07-03-2008 03:33 PM
GT3
04-24-2006 08:54 PM
B18Redline
12-20-2004 12:37 AM
type rizzy
08-31-2001 10:47 AM
