tapping starter?
tapping starter?
when a starter is bad, does the tapping trick always work? i just put a LS into my 95 civic and it wont start!! no crank or anything but it does make a quick noise from the starter like a zapping sound. i tried the tapping trick but no luck. does anybody have any ideas? i know that all my connections are right. the starter was bought used from a friend so i have a feeling it was a bad starter from the beginning. please helpp
Re: tapping starter?
You sure its not the battery? When a battery is left out it can be quick to drain. Especially the small ones that come in our cars. Give it a charge and see if that works. The tapping trick does work in most cases though.
Pull the starter and take it to you local parts house and have them test it for you. Its free and can give you a 100% for sure answer.
This is also a thought...have you made absolutely positive you have the right grounds and that they are clean? This will cause a no start condition with the symptoms you described as well.
Good luck.
Good luck.
yeh im gonna take out the starter tommorow when i get a chance and i will definitely double check my grounds just because you said something. hopefully its something that simple!
starter is good!! but all of a sudden i noticed that my radio and clock wasnt working eitherrr!! please somebody help me.. i want to drive my car so bad
the fuses under my hood isnt labeled as numbers. only names of what they are for. is fuse 32 for the radio and clock or does that fuse control something with the motor also. i checked the fuse under the dash for the radio and that one is good. also my ground connections are clean . i have a feeling it might be a bad distributor??
music and clock works!! thanks for the tip on fuse 32.. but my car still isnt running. how do i test the distributor to see if its not functioning right?
