turn signals not working
Old 04-18-2009, 07:23 PM
Swansen's Avatar
Default turn signals not working
... PO cut out turn signals, ordered dual mode LEDs to splice in, guy sent me wrong leads (as in wrong instructions for which leads do what, and their not logically color coded...) so go it all set, turned on the blinker, nothing flashed, and then it stopped clicking. Fuse 15 is fine, checked with test light, and from i understand, fuse 15 among other things, control the flashers. If anyone could help me out that would be great.
Old 04-19-2009, 06:00 AM
Swansen's Avatar
Default Re: turn signals not working
anyone? could it be the flasher relay? something else? did i miss something with the fuses? as it turns out, my backup lights don't work ether.
Old 04-19-2009, 09:48 AM
lindsley's Avatar
Does the hazard work? It might be a loose fuse connection
Old 04-19-2009, 10:54 AM
Swansen's Avatar
yeah, hazards work, but i saw on another thread that the backup light fuse has something to do with the blinkers, and then i also saw that the license plate light had something to do with the blinkers as well, and that one looked like it was burnt out, so i replaced both and now the blinkers work.
Old 04-19-2009, 09:32 PM
TheJGB3's Avatar
So you have resolved the issue?
Old 04-20-2009, 05:44 AM
Swansen's Avatar
yep, like i was saying, i replaced the two fuses, and the backup lights and the license plate lights weren't working. After i replaced both, the blinkers started working, (and then so did my backup and license plate lights).
jade butterfly
03-06-2006 09:13 PM
Matt_2078
16
10-20-2005 09:01 PM
O16581724 5 2 5
10-06-2005 10:03 PM
Quick Reply: turn signals not working
