How to chip and ECU??
I have all the hardware needed to chip my LS ecu, but I need pics of where they go?? anyone have any clue where I could find these??
ECU is OBD1 P75 95LS ecu...thanks guys...
Re: How to chip and ECU?? (SlowCivicHmm)
here you go, this link might help you out
http://www.autoserve.8m.com/St....html
Re: How to chip and ECU?? (b16a ferio)
thanks....
I know where teh "big" chip goes and the "lil" chip, but the resistor and teh jumper harness I'm not sure.....all the sites I find are P28's I have a p75......anyone ever chip one os these??
nothing special about the (1980-1502 board) P72/P75 boards. only difference is a lack of R54 (10k) resistor thats all.
74hc373, socket, jumper is still used.
check it out.
check it out.
Re: How to chip and ECU?? (eg6ajk)
so I just put in the big and lil chip?? no resister???
where does the jumper go?? can't seem to find where it goes..
eg6ajk...Damn nice of you man anytime someone has an ecu question you hop right in there. A lot of guys in your position would just say "mail it to me and I'll chip it"
Kudos to you.
Kudos to you.
the jumper is on J1.. thats the one that looks like a resistor but only has 1 stripe
add the 1.1k ohm resistor next to it R54.
stick 2 0.1uF ceramic disc capacitors into C51 and C52.
add the 74HC373 and the 28 pin socket for the rom
Re: How to chip and ECU?? (Zer0DazE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RangerDan »</TD></TR><TR><TD CLASS="quote">eg6ajk...Damn nice of you man anytime someone has an ecu question you hop right in there. A lot of guys in your position would just say "mail it to me and I'll chip it"
Kudos to you. </TD></TR></TABLE>
thanks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlowCivicHmm »</TD></TR><TR><TD CLASS="quote">so I just put in the big and lil chip?? no resister???
where does the jumper go?? can't seem to find where it goes..</TD></TR></TABLE>
J1 = jumper or 0 ohm resistor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Zer0DazE »</TD></TR><TR><TD CLASS="quote">the jumper is on J1.. thats the one that looks like a resistor but only has 1 stripe
one black stripe = 0 ohm resistor (jumper wire can be used or substitued with a computer pins & removable tab)
P74/p75/P72 does not have R54 location (btw. R54 used on 11FO and 1720 boards (obdi pr4/p06/p28/p30/p61/p91) uses a 10K ohm resistor - brown/black/orange/gold (5%))
thanks.
you can also use a piece of the wire from your resistor for the jumper
you dont need the capacitors or resistors
you can also go to hondata.com site and there is instructions
click on Downloads, go to installation manual (pdf file) and go to page 8 for obd-0 and page 9 for obd-1
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6ajk »</TD></TR><TR><TD CLASS="quote">
learned something new today... well i can go back to bed now.
alfaaay
04-07-2004 12:20 AM
