Weird *creaking* sound coming from suspension
Whenever I hit a bump, or anything that shakes the suspension, I hear a creak-type sound. I just replaced the struts about a year ago, and I don't have lowering springs. It sounds almost like some sort of joint is making that noise. Anyone have any ideas?
TIA!
TIA!
Re: Weird *creaking* sound coming from suspension (BCRUZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BCRUZ »</TD></TR><TR><TD CLASS="quote">stock springs?</TD></TR></TABLE>2000 ITR springs.
Could the sound be busted ball joints or something that I fucked up when removing my axles a while back for my swap?
Re: Weird *creaking* sound coming from suspension (monicle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by monicle »</TD></TR><TR><TD CLASS="quote">did you only change the springs or sis you change anything else with it? </TD></TR></TABLE>Springs + Brand new Tokico Blue struts.
Re: Weird *creaking* sound coming from suspension (94HybridEX)
i'm getting the exact same problem with my Si coupe...i have KYB AGX with ITR springs....someone please help...
Re: (Panda EK)
mine does that too...practically new springs and shocks (h&r and koni yellows)
I was just @ honda for service and they didnt tell me the ball joints were bad, so I dont think its them
Hmmm, i was having a similar problem over the winter. My passenger side rear was making a creaking sound over bumps.
I just jacked it up and sprayed some silicon lube on the rubber piece between the top of the spring and upper spring perch. Hasn't made a peep since...
When I installed my Illuminas (stock springs), the front suspension started creaking that way a couple of days later. The nuts at the top of the shock were too tight, so the bushings at the top of the shock were compressed too much. I loosened the nuts, let the car sit there for a couple of hours so the bushings could relax, and re-torqued the nuts to Tokico's spec (something like 10 ft-lbs). The creaking went away. It might take a couple of "sessions" depending on how deformed the bushings are.
Re: Weird *creaking* sound coming from suspension (mph6563)
Thanks for all of that advice.
You know how you have to separate the joint to remove the wishbone and then the axle? Well, when we finally got them separated, we had squeezed a lot of grease out, so that may also be my problem.
klion22
04-02-2008 01:50 PM
