Strange Rattle coming from driver's window
I have a strange rattling sound coming from my driver window...I notice it when i get in the high rpm range. Its sounds like its coming from inside my door. After my accident, i notice that the window doesnt go down all the way so that it sits flush with the weather stripping..any ideas?
1 Post
Re: Strange Rattle coming from driver's window (HighLife)
take off your door panel, peel back some of the plastic and takea look. it could be something as simple as one of the bolts that holds your window in place or any one of the bolts/screws that keeps your stuff in place.
Is there a easy way to get the panel off? Think I would be able to do it alone or you think i would need someone to help? Or maybe a nice cheat sheet on a website on how to remove the panel?
Thanks for the help.
Re: (HighLife)
Take off the door panel pull handle. Phillips head screw inside of it.
Take off the door lock surround.....one small phillips head screw under the door latch.
Take off the plastic screw that shows when you open the door (near where it sits flush with the dash)...if you have one.
Take off the window crank (have to have a tool, if not, a thin flathead screwdriver might work)
After that, just stick your fingers under the lip of the panel and just pop it straight off.
DOHC_VTEC69
02-03-2005 11:39 AM
Red_EM1
14
05-11-2004 09:31 PM
civic-si-2000
09-02-2003 05:47 AM
