Boot Leak Problem? and Oil Leak? Help
In this picture, where i circled, the boot is broken.
How do i replace it with a new one?
This picutre is where the driver side axle is, and the stuff is leaking where the boot is, how can i fix this? Is not broken or anything.
And finally, that is leaking, is there anything i can do to fix this?
thanks
thanks
Re: Boot Leak Problem? and Oil Leak? Help (intezn)
Buy a whole new axle and replace that, it will save you time and give you a lot less stress. Also for your other leak I think that it's coming out of the cam seal just replace they cost about four dollars.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by intezn »</TD></TR><TR><TD CLASS="quote"> more help please</TD></TR></TABLE>
He just gave you all the help you need! The cam seal is pretty self-explanatory and the axles can get rebuilt if you want. Take them off and take it to Honda (double check with Honda first) or some other place that can rebuild your axles and get them rebuilt. Or just buy new axles and be so fresh and so clean!!!
what about this?
what can i do with this then?
about the axle, i might as well just get a new one along with replacing the cam seals.
thanks
thanks
xXxHOLYMANxXx
10-17-2011 10:07 AM
