Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Steering and Suspension Guides
- How to Replace Tie Rod Ends
Step by step instructions for do-it-yourself repairs.
[FAQ] Tie rod end removal
Re: tie rod end removal (HuskerHybrid)
Just tried to do mine, but couldnt get it off....took it to a shop and they did it for $20 a side.....you will also HAVE to to an alingnment.......
Re: tie rod end removal (civicvteckid)
Real easy man. First remove this nut:
Nut loosened:
Then use a fork or tie rod puller to separate the ball joint. This should be really easy because if you're replacing it your ball joint is probably already bad. I found that hitting the threads of the joint from the bottom with a sledge hammer works very nicely.
Then the tie rod end just unscrews right off. Very Easy.
Pics of old vs. new tie rod end:
Nut loosened:
CXHatchback: thanks for the help bro, i'll be going to the salvage yard for a new one, thanks again... awesome pics/info
Re: tie rod end removal (CXHatchback)
Nice instructions.
By the way: How much did that new piece run? If you don't mind saying. And is that a gen. Honda piece or aftermarket/reman.?
Thanks,
G
Thanks,
G
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HuskerHybrid »</TD></TR><TR><TD CLASS="quote">CXHatchback: thanks for the help bro, i'll be going to the salvage yard for a new one, thanks again... awesome pics/info </TD></TR></TABLE>
i woulndt reccomend going to a junkyard to get a replacement tie rod...i bout mine brand new from napa for 28 bux
My car vibrates at speeds above 80 mph, so I went to get an alignment. The guy at the shop said my tie rods are "shot". Does this mean I need to replace the ends like this?
Re: tie rod end removal (94HybridEX)
when i hard right turn my car shutters and the boot at the ball joint is split open like the picture above. Do you think the tie rod or steering axle is causing this problem? Lemme know what you think
Re: tie rod end removal (snail)
Yes folks, if you're steering is really loose, REPLACE THOSE TIE ROD ENDS!! I replaced mine and the steering was soo much tighter I was amazed. A lot less shaky at high speeds too. And really easy to do yourself.
They were oem but I bought them from someplace online for $15 each.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CXHatchback »</TD></TR><TR><TD CLASS="quote">Yes folks, if you're steering is really loose, REPLACE THOSE TIE ROD ENDS!! I replaced mine and the steering was soo much tighter I was amazed. A lot less shaky at high speeds too. And really easy to do yourself.
They were oem but I bought them from someplace online for $15 each.</TD></TR></TABLE>Thanks, I'll definatly be doing this in the next couple of days.
stupid question:
my car sticks when turning one direction.. could it be the tie rod or do you think i need a new rack/pinion assembly?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by snail »</TD></TR><TR><TD CLASS="quote">geunine honda ones run ~$30 from hondaautomotiveparts.com</TD></TR></TABLE>
Yeah, I just looked it up. They are numbers 23 and 26 in the picture. $26.56 a piece. Heres the link:
http://www.hondaautomotivepart...R+BOX
G
G
Re: tie rod end removal (Mac8008)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mac8008 »</TD></TR><TR><TD CLASS="quote">My tie rod end has alot of play by the ball joint part. Is it possible to just replace the ball joint and keep the tie rod?
thanks</TD></TR></TABLE>
the tie rod end comes as one piece. plus you wouldnt want to go through the trouble of just replacing the ball joint, cuz you'd need a hydrolic press. another thing with these tie rod ends, once you replace them youre gonna need an alignment. once you take off the tie rods, youre alignment is gonna be off, uless you can put it on exactly how it was before but that's impossible cuz every tie rod isnt made exactly like the next one. so get those alignments and save money on tires.
I just did mine along with a manual steering rack swap.
The tie rods ran me $23 a piece from Honda. No new nuts with 'em though. That was the only downer.
Re: tie rod end removal (SilverCivic2k)
if you dont move the location of the locking nut then you wont have get an alignment, just crack the nut but leave it where it is on the threads, then unscrew the tie rod end, when you put the new one on it will be in the same position as the old one... autozone sells tie rods for 25$ per side, no core charge, lifetime warantee. you can do the install yourself in like a hour or two.
Old topic but...
is it hard tu pull off the ball joint??...
do we need the proper puller or I'll be able with somes basic tools??
Re: tie rod end removal (SlowCivicHmm)
I believe replacing the inner tie rod requires a lot more work. Sadly, I wrecked the car before I ever got around to try replacing it.
