State Ref visit, need some help now...
Old 04-29-2003, 12:42 PM
hybrider's Avatar
Default State Ref visit, need some help now...
well the Visual part of the test went fine, welp minus the p28 ECU i was running (couldnt find my friend to get my p72,damn't )
Comprehensive Visual Inspection: TAMPERED (ecu)
Functional Check: PASS
Emissions Test: GROSS POLLUTER :\
now i failed the emission test on high HC and CO numbers, take a look...
Idle Emission Results
HC #'s
Max- 100
GP-250
MEAS 443
CO #'s
MAX- 1.00
GP- 2.50
MEAS- 1.26 (idle-1036rpm & 1.78 MEAS 2500rpm-2588rpm)
[MEAS = amount measured] --- [GP = Gross polluter limits] --- [MAX = maximum allowable emissions]
now what could cause these high HC and CO emissions? can anyone analyze for me? i guess its time for a diagnosis, any smog station will help me correct?
Thanks In advance ppl.
Old 04-29-2003, 12:45 PM
rodrez.'s Avatar
Default Re: State Ref visit, need some help now... (hybrider)
Was it a reprogrammed ECU?
Old 04-29-2003, 12:48 PM
1999all_motoR_teg's Avatar
If it's a chipped ECU that's your problem right there. They cause you to run richer then the stock. Get a stock ECU, Put in the highest available octane in your area, retard your timing, drive around on the highway for about 15-30 minutes then go take the test and you should be fine.
Old 04-29-2003, 12:50 PM
monicle's Avatar
introduce the ref to a couple of your dead president friends. just kidding good luck though.
Old 04-29-2003, 01:01 PM
degooser's Avatar
wow i just went through the same **** but my readings were totally off....
my visual was fine...
emissions were crap face...gona have a friend check it out...
good luck...id get a usdm p72 and work from there...
chipped p28 probably throwing a lot of fuel in there...
Old 04-29-2003, 05:09 PM
hybrider's Avatar
Default Re: State Ref visit, need some help now... (degooser)
yes it was a "mugen" chipped p28, can that alone cause those numbers?
thanks ppl
Old 04-29-2003, 05:34 PM
rodrez.'s Avatar
YES. It will fail everytime with that computer. Just swap it out for stock ECU and you should see MUCH better numbers on the smog dyno.
Old 04-29-2003, 06:23 PM
Default Re: State Ref visit, need some help now... (rodrez)
Yah Rodrez is correct the mugen and Skunk2 programs are the worst for running rich I have the Skunk2 and in order for me to pass I had to go to my stock ECU and retard the timing
Old 04-29-2003, 06:50 PM
hybrider's Avatar
Default Re: State Ref visit, need some help now... (CIVICVTI2)
interesting, thanks all...
Sinology
10-20-2009 03:57 PM
killrB
02-09-2008 07:03 PM
hybrider
04-30-2003 12:44 PM
trustbuddy
04-22-2003 10:15 PM
Quick Reply: State Ref visit, need some help now...
