Rear disc swap + adjustable camber
In a few weeks I plan on doing a rear disc swap on my HX. My question is, do I use and adjustable camber kit for the integra gsr or for my model car (civic HX)? Or will they both use the same arm?
1 Post
Re: Rear disc swap + adjustable camber (jolt-tsp)
they are both the same just get one for the civic and youll be fine. the only things that wont work is the lower controll arms from the teg.
1 Post
if you need pics from an install you can check mine out here.
http://repo.jackmoves.com/view...bum55
Re: Rear disc swap + adjustable camber (monicle)
Awesome, thanks again. One more question. Did the brakes feel normal after the swap? Or is the petal travel much greater?
1 Post
my pedal felt pretty mcuh the same and i didnt even switch out the prop. valve. the fronts still engage before the rears, but youll probably notice less fade if you do any heavy braking.
Classic EF9
08-28-2009 11:54 PM
Slammd Sol
07-30-2007 12:07 PM
dng
05-25-2004 07:29 AM
