EP or DC5 steering wheel into the EG
Will it work without modifications? If it does require modifications then will the DC2R one fit without modifications? (the SRS one)
Re: EP or DC5 steering wheel into the EG (mixmastabob)
neither will bolt right up. The DC2R should bolt right up though, but i think the jdm(momo) type one came w/o SRS. The USDM R's came with the same steering wheel as the other integras just minor cosmetic differences , I think.
The EP or DC5 wheel will work with ek's.
The EP's hub is ok with an EK however the SRS plug is different then the EK SRS plug so the airbag is non functional.
The JDM DC5 Wheel mounts up perfectly and the SRS plug is the same as the EK SRS plug so its plug and play.
For the EG you would need a DC2 steering wheel for the hub, not sure if the SRS plugs are the same.
I think you could put the steering colum in from the ep.
I wanted to try for the ctr because I have the steering colum
but no wheel. Has anyone tried?
Bloody Hatch
01-28-2009 07:27 AM
frampo
11-28-2005 12:52 AM
