Wiring a 99 civic SIcluster in my 98 DX(already searched, please help!)
I have a 98 civic dx and i need to get a wiring diagrapm to install my 99 Si cluster. Thanks and sorry i searcxhed and couldn't find the topic...
Re: Wiring a 99 civic SIcluster in my 98 DX(already searched, please help!) (chrisir19)
simple, take the si cluster and plug it in to your exsisting wiring harness.
Its that easy.
There is no point in cutting wires or anything, its plug and play and everything will work fine.
Its that easy.
yep...you dont need to rewire anything...just plug it in and off you go
Re: Wiring a 99 civic SIcluster in my 98 DX(already searched, please help!) (pdiggitydogg)
unscrew the 2 screws on the top inside of your gauge bezel, then pull gently from the bottom (the bottom is held on by clips. once the black housing is removed, unscrew the 4 screws on the corners that hold the cluster to the dash. unplug the 2 or 3 plugs connected to the cluster and plug the si cluster in. reinstall everything. done
well what the **** is the green harness that i clipped out of the si dash harness? thanks for the help...a bout to wire it up or PLUG it in...what is this green cplug???? grrrhhhhhhh!!!!!! help
Probally some **** that you don't need.
I only have the two big ones pluged up, the ones at the top of the cluster.
probally has to do with cruise control, or something.
Re: Wiring a 99 civic SIcluster in my 98 DX(already searched, please help!) (black2kcivic)
Green plug is cruise control, Yellow is SRS.
Just plug it in already f00!
MyEvo8GotRepo
07-18-2005 11:55 AM
AIWFCIATR
09-24-2004 12:37 AM
enrique
12-29-2002 09:18 PM
