SRS Light
Good question since I need to get rid of mine too. I belive you can just take out your cluster and disconnect it, but there might be a way to trick the system so it doesn't display the light too.
I'm pretty sure there is a 2-pin harness under the dash for the airbags, if you disconnect it the light may go off, or it might cause the light to go on too
i would try. Also, what about the fuse under the dash for SRS? If all else fails I would just remove the bulb.
http://www.7thgencivic.com/mod...id=19
either this, or juss put black tape over the light, oh yea, read the link and if u leave a paper clip in the srs connector, it would stay off too.
wardseg6
Oct 17, 2006 01:15 PM
PDXHatchback
Mar 23, 2003 06:32 PM
