will a b series clutch fit a d series?
will a b series clutch fit a d series? my friend says it will, but i need to be sure. the reason i'm asking is because my friend has a clutch off a b series that is still pretty new, and my clutch is erased. i'm going to that clutch off of him if i can use it on my car.
Re: will a b series clutch fit a d series? (civicdxtyper)
noooooooooo noooooooooo nooooooooo nooooo noooo. you would start screwing up you car doing that. i've known someone who did that. 4 day's after install. the clutch was completly gone. even big holes.
Re: will a b series clutch fit a d series? (TrickHonda77)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TrickHonda77 »</TD></TR><TR><TD CLASS="quote">noooooooooo noooooooooo nooooooooo nooooo noooo. you would start screwing up you car doing that. i've known someone who did that. 4 day's after install. the clutch was completly gone. even big holes. </TD></TR></TABLE>
just curious, what is the difference? are the clutches just a different size, or is how the clutch built different or something?
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TrickHonda77 »</TD></TR><TR><TD CLASS="quote">noooooooooo noooooooooo nooooooooo nooooo noooo. you would start screwing up you car doing that. i've known someone who did that. 4 day's after install. the clutch was completly gone. even big holes. </TD></TR></TABLE> i dont know how ur friend put it in in the first place cause the tranny shaft from the b series wont fit in the d series clutch in the first place...more splines in the b series than d...
Re: will a b series clutch fit a d series? (tangb2023)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tangb2023 »</TD></TR><TR><TD CLASS="quote"> i dont know how ur friend put it in in the first place cause the tranny shaft from the b series wont fit in the d series clutch in the first place...more splines in the b series than d...</TD></TR></TABLE>
Exactly what I was thinking. It shouldn't have fit at all.
98slowvicEX
05-05-2012 07:27 AM
