Electrical Problems---VERY URGENT!
Well, today I was changing my oil and I ran into a few problems.
1) My turn signals are messed up. My right one works ok, except it stays lit(on the guage cluster and in the tailights) when I turn the corner lights/headlights on. Also, sometimes it will work ok, but the rear license plate lights flash with it.
2) My left side, only the rear blinker works, but it does it in "hyper" mode. And the front corner light doesn't blink at all...only the rear tailight.
Anyway, I was working on trying get this somewhat straightened out, and I noticed that my "check engine" light was on. So I check the wires and found out that a couple of them had been disconnected somewhere along the line. So I re-wired it and the "check engine" light doesn't come on!
To make this short, while my friend was playing around with the right turn signal, he seemed to have blown a fuse. Now, the tach, speedo, gas gauge, temp guage, milage gauge etc.... DO NOT WORK. I checked all the fuses and replaced all the ones that seemed to relate to turn signals/gauge cluster etc....NOTHING worked.
What should I do? I need the car for work on Mon, so I'm hoping its a easy fix. I've had this happen once before, but I can't remember what I did to fix it.
HELP!
Thanks,
Spike
P.S. Sorry is this is somewhat confusing. I'm VERY tired and coming off a week full of 14 hour work days.
HELP!
Thanks,
Spike
Re: Electrical Problems---VERY URGENT! (BikeSpike)
well if it blink in hyper mode on the guage means the light is out or theres a short circuit somewhere..if u check all the fuse under the dash and everything is ok..then it must be the fuses in ur engine bay..its right next to the battery..gl
Ran4it2
05-18-2009 10:14 PM
CaptainQuirk
07-11-2007 12:09 PM
dpine
12-11-2005 08:59 PM
