Brake lights won't work!
I've checked everything to the best of knowledge and the brake lights would still not work. Everything else is working fine! Can you guys think of anything else I can check. Thank you!
BTW, It's 92 Civic Si.
Re: Brake lights won't work! (Unknwn_1)
probobly your brake light switch... it's attached to the brake pedal... check to make sure the pedal is contacting/tripping it... if it is then either replace it with a known good one (new) or you can try working around the switch just to see if that's it... however I don't know if it's a ground or a power... but you should be able to just splice the 2 wires going into the switch to see...
good luck
good luck
