z6 cam into y8?
Old 07-11-2003, 09:59 AM
DV98CVC's Avatar
Default z6 cam into y8?
i have a spare z6 head with a aem cam gear...i wanna put the cam gear on my y8, but i know it wont fit on my cam, so will the z6 cam swap into the y8 head? or do i have to swap the whole head?
Old 07-11-2003, 10:08 AM
Daniel's Avatar
Default Re: z6 cam into y8? (DV98CVC)
I've been researching this, too. From what I've found through archived posts, the Z6 cam will fit into the Y8 head. However, I've read a lot of discrepancy about what will need adjusting--some say only the cam timing via a cam gear and others say both the cam timing and ignition timing. I haven't found a definitive answer yet. Those who say the ignition timing is off say it's off by a lot.
Old 07-11-2003, 10:14 AM
DV98CVC's Avatar
Default Re: z6 cam into y8? (Daniel)
thanx...could you keep me posted on your research?
Old 07-11-2003, 10:17 AM
Daniel's Avatar
For sure. I'm going to stop by my local shop today and see what they say. Hopefully someone there will know.
Old 07-11-2003, 02:44 PM
kommon_sense's Avatar
my understanding is that the z6 cam will fit into a y8. However your timing will be off In order to correct this, you will need a z6 cam gear as well.
Old 07-13-2003, 02:00 PM
DV98CVC's Avatar
Default Re: (kommon_sense)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kommon_sense &raquo;</TD></TR><TR><TD CLASS="quote">my understanding is that the z6 cam will fit into a y8. However your timing will be off In order to correct this, you will need a z6 cam gear as well.</TD></TR></TABLE>
Do you have experience with this or know anyone who does?
Old 10-01-2003, 02:32 PM
DV98CVC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Daniel &raquo;</TD></TR><TR><TD CLASS="quote">For sure. I'm going to stop by my local shop today and see what they say. Hopefully someone there will know. </TD></TR></TABLE>
...soo...whats the final word? fit or not fit?
Old 10-01-2003, 02:49 PM
liam821's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DV98CVC &raquo;</TD></TR><TR><TD CLASS="quote">i have a spare z6 head with a aem cam gear...i wanna put the cam gear on my y8, but i know it wont fit on my cam, so will the z6 cam swap into the y8 head? or do i have to swap the whole head?</TD></TR></TABLE>
Im using a y7 cam gear on my z6 head - so im sure you can use a z6 cam gear on a y8 head. Ive also used my "str" cam gear on my z6 and also my friends y8.
Its the same gear, same everything.
liam
Old 10-01-2003, 03:13 PM
DV98CVC's Avatar
Default Re: z6 cam into y8? (liam821)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by liam821 &raquo;</TD></TR><TR><TD CLASS="quote">
liam</TD></TR></TABLE>
no its not...the z6 and y8 cams are different...the z6 gear wont fit the y8...i just wanna know if a z6 cam will fit in a y8 head...?
Old 10-01-2003, 03:25 PM
liam821's Avatar
no its not...the z6 and y8 cams are different...the z6 gear wont fit the y8...i just wanna know if a z6 cam will fit in a y8 head...?</TD></TR></TABLE>
im using a y7 gear on a z6 cam..the two gears are identical..other then they look different.
Also the y8/z6 cam can be swapped...however the y8 is more aggressive.
cam | advertised duration | duration @ .050" | gross lift w/ 1.6int/1.8 exh
D16Z6 244 / 228 | 208 / 192 | 384 / 370
D16Y8 246 / 230 | 208 / 191 | 393 / 369
liam
Old 10-01-2003, 03:28 PM
axhandler's Avatar
Yes it will. The Skunk2 SOHC cam is made for the Z6 motor. I have it installed in my Y8 head right now. Actually, I bought it from Daniel...who had it in his Y8 motor for a while.
Not sure about the gear crap but the cams are about the same. The difference lies in the timing. The cam timing has to be advanced about 4 degrees if you put the Z6 cam in the Y8 head.
Check my dyno post if you want more info on my setup...
Old 10-02-2003, 02:56 AM
D Tranny Guru
Mista Bone's Avatar
Default Re: z6 cam into y8? (axhandler)
so you have a Z6 cam in a Y8 head with no cam gear correction????
The dyno files are useless until you correctly degree in your cam.
4.75 degrees at the camshaft, learn to degree ut!!!!!
Old 10-02-2003, 05:06 AM
SOHC_MShue's Avatar
you want to go to the trouble of swapping a z6 cam into your y8 head just to have a cam gear? A cam gear won't do **** without an aftermarket cam in there.
Old 10-02-2003, 05:33 AM
DV98CVC's Avatar
Default Re: z6 cam into y8? (SOHC_MShue)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue &raquo;</TD></TR><TR><TD CLASS="quote">
you want to go to the trouble of swapping a z6 cam into your y8 head just to have a cam gear? A cam gear won't do **** without an aftermarket cam in there.</TD></TR></TABLE>
no ****, that was my plan...but i'm not gonna by a y8 aftermarket cam if i can get a z6 aftermarket cam and use the gear with it...
Old 10-02-2003, 06:12 AM
luti's Avatar
It will fit, and the timing is somewhere between 4 or 5 degrees advance in the Y8 head to get it to the relative 0 degree mark. I had a Zex stage 1 cam (51900? 59100? I cant remember the number) which is cut for the Z6 and had a Skunk2 cam gear. Ran perfectly when I advanced the gear a few degrees. Most companies only cut one cam for the 2 engines and just make it a Z6 cam expecting you to know to advance the timing, to bad they don't make that info more publicly available.
Old 10-02-2003, 08:22 AM
axhandler's Avatar
Default Re: z6 cam into y8? (Mista Bone)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mista Bone &raquo;</TD></TR><TR><TD CLASS="quote">so you have a Z6 cam in a Y8 head with no cam gear correction????
4.75 degrees at the camshaft, learn to degree ut!!!!!</TD></TR></TABLE>
No dude...that why I said the cam had to be advanced ~4 degrees. But you cant just say "advance you cam exactly 4.75 degrees" because it will depend slightly on the individual motor. The tuning has to be done on the dyno to get it exactly right. Mine tuned out right at 4 degrees.
Old 10-02-2003, 08:24 AM
Daniel's Avatar
...soo...whats the final word? fit or not fit?</TD></TR></TABLE>
Whoa, sorry about that. As said before, a Z6 cam will fit in a Y8 head. You just need to adjust the timing, which I did with a Skunk2 cam gear. But as a result of dyno tuning and everything, my tuner and I ended up finding out that my compression was low (dismal results--&gt;check stuff--&gt;find out compression is low). I ended up selling the Skunk2 S1 cam and Skunk2 cam gear to axhandler, as he already mentioned.
Old 10-02-2003, 09:00 AM
SOHC_MShue's Avatar
no ****, that was my plan...but i'm not gonna by a y8 aftermarket cam if i can get a z6 aftermarket cam and use the gear with it... </TD></TR></TABLE>
my b....it sounded like you wanted to put it on a stock z6 cam in your original post.
00ejhatch
12-05-2013 05:04 PM
rainmanef
07-13-2005 01:42 PM
SOHC_MShue
02-07-2004 06:18 AM
Hybrid
06-19-2003 09:37 AM
dremmel
03-20-2003 10:43 AM
Quick Reply: z6 cam into y8?
