Help! Oil in Spark Plug Cylinder
Re: (BrynnTheSlut)
Take the valve cover off and where the sparkplug holes go there are Spark plug grommets. Lots of times those grommets are busted and allow oil down in the sparkplug hole. Go get a Valve cover gasket kit and they will come in there. Takes maybe 5 minutes to do this.
Re: (BrynnTheSlut)
Could be a bad gasket, just go to honda and buy a valve cover gasket kit (i think thats what its called) and you will get spark plug gaskets also. Change em all.
Re: (Evil_Wizard)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Evil_Wizard »</TD></TR><TR><TD CLASS="quote">Take the valve cover off and where the sparkplug holes go there are Spark plug grommets. Lots of times those grommets are busted and allow oil down in the sparkplug hole. Go get a Valve cover gasket kit and they will come in there. Takes maybe 5 minutes to do this.</TD></TR></TABLE>
That's exactly what you have to do... same thing happened w/ mine.
i had to change the gromets last week in my accord, not hard to do at all. i just used paper towels to soak up the oil before i took out the plugs, you'll exhaust will smoke for a while its normal since some of the oil will get in. goodluck
Re: (SlippylesKB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlippylesKB »</TD></TR><TR><TD CLASS="quote">
That's exactly what you have to do... same thing happened w/ mine.</TD></TR></TABLE>
Same here... about to do the gasket change over this afternoon.
