Integra Seats Fitment?
How do you make 94+ integra seats fit into a EG hatch? do i need the integra rails or do i use my stock civic rails? or are they the same? also about the back seats would they fit the same or would they not fit good? please help. thanks
Re: Integra Seats Fitment? (d15b7racer)
Front seats bolt right in, don't need your rails. Integra ones work fine. The rear seats will work but you will have a slight gap. not real bad though.
Re: Integra Seats Fitment? (turbocivic4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbocivic4 »</TD></TR><TR><TD CLASS="quote">so the integra seats 94- fits in 92-95 interchangeable?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nema741 »</TD></TR><TR><TD CLASS="quote">Front seats bolt right in, don't need your rails. Integra ones work fine. The rear seats will work but you will have a slight gap. not real bad though.</TD></TR></TABLE>
In other words... yes.
I used to have teg seats in my EG. The gap mentioned isn't that bad. Take a look below.
Damn now that I look back my hatcy I'm kinda sorry i sold it.
Guest
Posts: n/a
Re: Integra Seats Fitment? (big jul)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by big jul »</TD></TR><TR><TD CLASS="quote">I used to have teg seats in my EG. The gap mentioned isn't that bad. Take a look below.
Damn now that I look back my hatcy I'm kinda sorry i sold it. </TD></TR></TABLE>
not a big gap?
to me it seems like theres a big opening on the left side...
showing the green body....
not a big gap?
Re: (2000CX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2000CX »</TD></TR><TR><TD CLASS="quote">kinda off topic but how about ek's with the 94+ teg seats...same deal?</TD></TR></TABLE>
I was wondering the same thing.
Re: (2000CX)
up for an answer...anyone?
Re: (2000CX)
Rear seats, very little gap. I shoved black fabric around the sides to hide it and it works very well.
Front seats fit perfectly, direct bolt in as stated before.
-Jake
-Jake
Re: (2000CX)
yup
yup
1 Post
for an EK the front seats will fit, but one of the bolts doesnt line up. My friend had the ITR seats in his EK and they felt sorta loose becasue he didnt have one of the bolts in. Do a search and im pretty sure something will come up on how to do it correctly.
Re: (BrynnTheSlut)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BrynnTheSlut »</TD></TR><TR><TD CLASS="quote">for an EK the front seats will fit, but one of the bolts doesnt line up. My friend had the ITR seats in his EK and they felt sorta loose becasue he didnt have one of the bolts in. Do a search and im pretty sure something will come up on how to do it correctly. </TD></TR></TABLE>
isn't that kinda of dangerous, like seats come flying off and ****?
I installed 94 integra cloth seats and had a HUGE gap. It must have been 1.5 inches. I took them out and now i'm riding with the old blue seats.
Down Since Day 1
I just put 98 GSR seats in my 94 EX, i just put my EG rails on the GSR seats, no gaps, no nonsense. All 4 bolts and they sit lower. GSR rails sit higher to. Just swap the rails, takes like 20 minutes. 10mm, 12mm, 17mm your all set.
Also sometimes when people have gaps they put them in wrong. You put the seat in, put all 4 bolts in only hand tight, not even all the way down. Once all 4 are in, then you go around and tighten them.
Pic is kinda big so ill post the link...
http://www.we-todd-did-racing....DE%3D
Re: (Happyman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Happyman »</TD></TR><TR><TD CLASS="quote">I thought that only 3 of the 4 bolts matched up from a teg to an eg? or was that teg to ek?</TD></TR></TABLE>
That is EK to EG if I remember correctly.
Fronts fit fine.
Coupe GSR rear seats in hatches look like ****. There is a huge gap on the sides of the bottom seat, the back of the bottom seat isn't the problem. They just do not fit. You might as well put a couple pillows down for people to sit on.
The correct way is to use a sedan bottom seat and coupe top. Then it's close to perfect. Yes, this is spoken from experience.
This is for 92-95s.
This is for 92-95s.
Re: Integra Seats Fitment? (SkyeC)
Well heres the deal today what happened.
My 93 civic coupe got Recaro SRD seats and my 94 Integra got 00 leather seats. So I put my leather seat in my coupe and 3 bolts looked to be able to line up. When I put my Recaro SRD in my Integra only 2 rear bolts line up the front ones seem not to want to fit at all.
What the hell should I do to get my SRD's in my teg order new brackets or do silly modifications that wont have it sit perfect
Too lazy to read entire thread so if I repeat anything please forgive me, its late. Just purchased and installed some integra fronts out of an 94 Ls today. The inner rails of the integra seats have to be swapped with the eg seats and then they will line up perfectly hope that helps. Once again my apologies if I repeated anything that has already been said.
supracrx
04-25-2006 06:19 PM
