question about autometer oil pressure gauges
i have 2 autometer oil pressure gauges. one is a mechanical gaulge which requires a steel braided oil line to be run from a T fitting from the back of the block and i have a oil pressure gauge that is electrical. both read oil pressure in PSI but i want to use the electrical oil PSI gauge because i already have my turbo oil feed line using the t fitting. how would i use the electrical gauge? where does the signal wire for the gauge go on a honda motor?
Re: question about autometer oil pressure gauges (nextelbuddy)
that very same sensor that you T-eed your oil line for your turbo should have a oil pressure sensor, tap that line(wire) i beleive that is the sending unit.
Re: question about autometer oil pressure gauges (DOHCtorTHRUST)
i have a mechanical one, but i remeber the electrical having its own sending unit. i read it in an install in a magazine. am i wrong?
you can just replace your stock oil sending unit for the mechanical one and you do not need a steel braided line for it. you can buy a kit for 5 bucks at pepboys or autozone and it has all the fittings and oil line you will need. much easier and cleaner install.
Re: question about autometer oil pressure gauges (akumaracer)
ok so i had to give up the mechanical oil pressure gauge since it was my friends and he wanted it back so now im stuck with teh electrical oil pressure gauge. i know the guysaid above aobut a separate sending unit for electrical gauge so i went to teh parts store ancd couldnt find what he was talkig about. can anyone give me some insight on how to hook up this electrical oil pressure gauge? am i missing a part or sending unit? since this gauge is electrical? id much rather use this gauge so i dont have to have a oil line form teh back of my block to the inside of my dash.
_______
_______
not sure if it will help you much now. but AC Autotechnic makes this little mounting bracket thing for oil pressure gauges. its availiable at autodynamic.
http://www.autodynamic.com/det...OS10x
Re: question about autometer oil pressure gauges (snail)
Vtak
04-29-2005 11:24 AM
W O T
01-29-2005 08:01 PM
