Need help with these......
Ok a friend give me (for free) his integra LS swaybars, front and rear. I want to now if those bars fit in my CX ek Hatch ??
here are the swaybars
rear:
Front
rear:
Front
Re: Need help with these...... (bulori)
I'm pretty sure they will fit if you buy a install kit from beaks. It should be similar to installing the itr bars. Don't take this to be one-hundred percent true because I'm not sure. If you use the search function it will give you what you need.
Re: Need help with these...... (solsteeler)
the front bar won't fit. it will bang against the shift linkage. acutaly it will prevent shifting entirely. at least it did on my friends 00 cx hatch.
edit: i don't think the rear will mount to your subframe with the stock dc brackets. the ek civic has a different design of the subrframe
Re: Need help with these...... (95excoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95excoupe »</TD></TR><TR><TD CLASS="quote">They wont do much anyway I would suggest at least a 19mm in the rear</TD></TR></TABLE>
well its better something that nothing !
vtec4max
10-17-2006 06:41 PM
96EK_civhatch
09-09-2004 04:07 PM
ekHatchTDot
05-13-2003 04:58 PM
