Fuel Pump install question on 93 Hatch???
I have never done a fuel pump before so I am going to try and attempt it. I guess I relieve the fuel pressure first and disconnect the negative battery terminal. After that I remove the fuel feed hose off the tank. I guess the rest after that is a snap. Please correct me if I am wrong. Thanks
Re: Fuel Pump install question on 93 Hatch??? (importimage)
yeah. but i didnt disconect the battery or relieve th fuel pressure and i was fine. there is a plug and a fuel line that u take off. then just replace the pump
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by importimage »</TD></TR><TR><TD CLASS="quote">When you disconnected the fuel line, did you get a lot of gasoline leaking out?</TD></TR></TABLE>
not even the size of a shot of alcohol. at most like a total of 10 drops
Mr. Vapor
03-25-2002 06:23 PM
