No Sprak!! Dead Dizzy?? Rotor Screw??
No Spark!! Dead Dizzy?? Rotor Screw??
If I have no spark, do I assume that the dizzy is dead? What can I check and how?
And how can you get the screw on the cap out if the dizzy isnt spinning the rotor? Is there any way to spin the rotor so that the screw is exposed?
Re: No Spark!! Dead Dizzy?? Rotor Screw?? (itsmike)
Check your ignition coil, or better yet buy a new one, and you also should check all ignition fuses i nthe main fuse box, and check if the cap is moist if it is moist it won't be able to send a spark. Also, how do you know you're not getting spark?
and get to get the cap off take the Dizzy off the engine and spin it yourself.
Hey check the ingniter also which is located inside the distributor. This part is
a dealer item and can cost bout 250 or more. so check your local salvage yard. If cheap enough grab 2. good luck
Re: No Spark!! Dead Dizzy?? Rotor Screw?? (civic_rice)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic_rice »</TD></TR><TR><TD CLASS="quote">
I just cranked the engine over very briefly until the screw was exposed </TD></TR></TABLE>
The rotor wont spin if the dizzy is dead... right?
