self adjuster on the drum brake not working!!
Old 07-25-2004, 02:11 PM
alleyezonme's Avatar
Default self adjuster on the drum brake not working!!
i have a 92 cx, and my drum brake will not self adjust. ill put new brakes on and in a month or so it will start squeeling and then my e-brake won't work. is this due to shitty springs? am i puttin it back together wrong?? a lil help here guys! thanks
alleyezonme is offline
Old 07-25-2004, 03:14 PM
Default Re: self adjuster on the drum brake not working!! (bumpincivic20)
c'mon, somone has to know what i am talking about!!
Old 07-25-2004, 03:16 PM
civicEXtreme's Avatar
Are you talking about the e-brake strength adjuster, like how tight the e-brake will be if adjusted thingy? Because if you are, you really didn't make it clear, I think.
civicEXtreme is offline
Old 07-25-2004, 05:19 PM
Default Re: self adjuster on the drum brake not working!! (civicEXtreme)
ohhhh no sorry!! i mean when i put new shoes on... i can adjust my ebrake and it will work fine until the shoes wear down far enough and they won't self adjust... like it won't push the shoes out the amount it needs to to compensate for what you have burned off. sorry it is kinda hard to explain!! i was wondering if i need to replace the springs inside of the drums, or am i just puttin the drums back together wrong after i change the shoes??
thanks
Old 07-26-2004, 08:54 AM
well, consider I know nothing about drums, I'm not the one to ask...
Old 07-26-2004, 08:58 AM
HCRX311's Avatar
Try replacing the springs in there, they dont cost that much. more then likely is them.
HCRX311 is offline
Old 07-26-2004, 08:59 AM
fakemike's Avatar
When you change the shoes you should have also replaced the springs. It costs about $7 and its called return spring kit or something.
fakemike is offline
Old 07-28-2004, 10:18 AM
Default Re: self adjuster on the drum brake not working!! (fakemike)
alright thanks guys
charlieboy88
01-04-2013 07:58 AM
averyvm
01-24-2010 03:11 PM
OneOhNine27
01-10-2007 02:03 PM
mikensu
05-26-2005 08:30 AM
Lo-Buck EF
11
08-31-2004 04:37 PM
Quick Reply: self adjuster on the drum brake not working!!
  • Ask a Question
Question Title:
Description:
