where to set v-tec
Old 07-25-2004, 03:49 AM
chulopilong's Avatar
Default where to set v-tec
i got a eg with a b16. i just got a v-tec controller. wher should i set my l~h and my h~l v-tec.
chulopilong is offline
Old 07-25-2004, 05:59 AM
Electrician
Deemeetree's Avatar
How about no Scott. You definitely need to take your car to a shop where they have a dyno and tune it. If you mess around with your V-AFC, you can definitley set all parameters WAY off and your car will run like ****. A V-AFC and S-AFC DEFINITELY has to be dyno tuned. Where do you know where you're going to make your power without a dyno?
Do you have cylinder head work or do you think just by advancing or retarding your VTEC crossover point you'll be able to gain about 30whp? It isn't going to happen. If you set your VTEC point too low, you can have extensive wear on your valvetrain.
Deemeetree is offline
Old 07-25-2004, 06:20 AM
Islandspeed's Avatar
Default Re: where to set v-tec (chulopilong)
Don't mess wih it yourself!!!! Take it to a shop with a dyno and do a few pulls. They'll find the best Xover between the high / low cams. Mine was set at 5250 RPM (Turbo B20/VTEC). I thought from what I'd read, and discussed with other people, the optimum Xover would be around 4800 RPM. You could spend quite a bit of time trying to figure it out and still be wrong. The computer doesn't lie.
Islandspeed
Islandspeed is offline
Old 07-25-2004, 06:47 AM
nd4sped's Avatar
My boy Tommy from Redline Motorsports in Savannah Georgia tuned my VAFC II to 5k
nd4sped is offline
Old 07-25-2004, 07:10 AM
91civicDXdude's Avatar
how about set it to stock parameters, which would be 5500 L-H and about 5000 h-l
91civicDXdude is offline
ArniFPR
01-08-2016 04:15 PM
stRodda
09-23-2003 03:32 PM
killa_lude
08-26-2003 05:10 PM
slowazzhatch
19
01-20-2003 11:34 PM
gamby
01-13-2002 05:15 PM
Quick Reply: where to set v-tec
  • Ask a Question
Question Title:
Description:
