HELP.. car is making a new noise
u know that sound when u turn ur key after ur car is already started. my car is making that sound when i crank it or turn it on. what is it? how can i fix it? ..thanks
Moderator
Re: HELP.. car is making a new noise (B18Cej1)
man....we are gonna need a better description of the sound....and better time frame of when this sound is happening
Re: HELP.. car is making a new noise (chad)
when u crank ur car to turn it on.. it makes that sound, but at the same time, its making that sound when ur car is already on and u turn the key. it starts fine and the noise goes away when im not turning the key ne more.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chad »</TD></TR><TR><TD CLASS="quote">man....we are gonna need a better description of the sound....and better time frame of when this sound is happening</TD></TR></TABLE>
its like that grinding noise, u should go and try it.
Re: HELP.. car is making a new noise (DewMota)
He means when your car is already on.
If you try to turn the key to the start position it will make a grindy vibration noise. Obviously this sounds like a starter problem, try a differant one
In the past if a starter continues to turn even after the car is started, I have been able to fix it by either just replacing the starter solenoid (piggybacked on the starter itself) or replace the entire starter (which is probably a good idea, cause you have probably ground down the starter gear a little by now). Either way let us know what happens
Even if it does right before or while your cranking I would guess that the starter gear is stripped and youu will need to replace the whole starter. It's not that bad I think there like $100 plus you get a core return. And the replacment time on it is like 30 mins.
Re: HELP.. car is making a new noise (mustninty)
cool. thanks man. is there ne thing i should watch for. if i disconnect the battery i should be fine right?
ok i replaced th starter and the cap and rotor. but when i went to my car my battery was dead. so i replaced the starter cap and rotor.. then.... i jump started it. and now the car wont crank and all im getting is the grinding sound. all i get is grinds. what do i do now? thanks.
or you starter needs to be lubed. My car did it when it's cold outside, so I took the starter apart and lubed the mechanism.
Not honda, but how different are the starters:
http://www.motorvate.ca/mvp.php/516
Re: HELP.. car is making a new noise (ABK)
bump, anyone else im really stuck. if it helps i drove from san diego to la and back driving pretty fast and all of this started happening the next day.
