Low Fuel Light....
Old 07-25-2004, 10:42 AM
civic_speed99's Avatar
Default Low Fuel Light....
I noticed that my low fuel light wasn't working when i ran outta gas downtown the other night... luckily i was right by the gas station and i got it started again.....
what could be the problem since it won't light up??
civic_speed99 is offline
Old 07-25-2004, 10:45 PM
ek9800's Avatar
Default Re: Low Fuel Light.... (civic_speed99)
either ur light bulb popped out or there was not one in there or its deffected
ek9800 is offline
Old 07-25-2004, 10:59 PM
Default Re: Low Fuel Light.... (jdm98hb)
I have the same problem too man. It sucks ***
skrewdriver88 is offline
Old 07-25-2004, 11:46 PM
vtecpower1062's Avatar
I had the same problem too recently, only I got stuck on I-95 and had to get towed . I am going to troubleshoot this with Honda service manual and ETM. Hopefully its something simple like a fuse.
vtecpower1062 is offline
Old 07-26-2004, 03:39 AM
JimmyAtlantis's Avatar
Default Re: Low Fuel Light.... (vtecpower1062)
Are you guys sure you even have a low fuel light? I know I don't - as in the car was built without one.
JimmyAtlantis is offline
Old 07-26-2004, 05:01 AM
photec2's Avatar
Default Re: Low Fuel Light.... (JRI94)
^ i was gonna say that also but according to your sig's 00 si and 99 EX im sure you have a low fuel light. In my case my 93 si doesn't even have one.
photec2 is offline
Old 07-26-2004, 05:07 AM
Sijray21's Avatar
Your guage works right?
Fill up before it gets to that point
Sijray21 is offline
Old 07-26-2004, 05:22 AM
CRITTERMATT's Avatar
most likely your sending unit needs replaced. The same thing happened to mine. The sending unit is located in the tank behind the fuel pump.
CRITTERMATT is offline
Old 07-26-2004, 08:05 AM
SlepT ej6's Avatar
Default Re: Low Fuel Light.... (Sijray21)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sijray21 &raquo;</TD></TR><TR><TD CLASS="quote">
Fill up before it gets to that point </TD></TR></TABLE>
definately
SlepT ej6 is offline
Old 07-26-2004, 01:03 PM
undertheradar's Avatar
Default Re: Low Fuel Light.... (SlepT ej6)
If my 97 Dx has one...yours does. I'd say it's the sending unit and or the bulb in the cluster. I'd check the bulb first though...it's easiest to get to and the cheapest to buy.
undertheradar is offline
Old 07-26-2004, 01:12 PM
doublejz's Avatar
Default Re: Low Fuel Light.... (CRITTERMATT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRITTERMATT &raquo;</TD></TR><TR><TD CLASS="quote">most likely your sending unit needs replaced. The same thing happened to mine. The sending unit is located in the tank behind the fuel pump.</TD></TR></TABLE>
No, as long as your gauge is reading correctly your sending unit works fine. The low gas light goes by the position (voltage) of where the needle is. If you have a light and its not working, its most likely your bulb
doublejz is offline
Old 07-26-2004, 02:49 PM
Default Re: Low Fuel Light.... (doublejz)
I have to disagree. Because mine quit working and once I replaced the sending unit it began to work. The low fuel light sensor is made into the sending unit.
Old 07-26-2004, 03:09 PM
soundbomber's Avatar
mine has never worked and i have a 98 dx
soundbomber is offline
Old 07-26-2004, 03:12 PM
Dyzee's Avatar
I've never had mine on. Heck I dont even know if I have one.
I drove my car almost 600kms on 35L of fuel and it still didnt come on. I got scared so I filled her up
Dyzee is offline
uhhkilleez
04-10-2012 05:30 PM
HondaScene
02-07-2012 08:30 AM
huckduck
08-18-2008 01:10 PM
Rikaro
10
06-25-2008 01:08 PM
Lookincrazy
05-06-2002 04:36 PM
Quick Reply: Low Fuel Light....
  • Ask a Question
Question Title:
Description:
