Is there a HOW TO on EK trunk light???????????????
Re: Is there a HOW TO on EK trunk light??????????????? (jes c)
Edit: you guys mean putting a light in your trunk so when you open it the light turns on right?
Why not go to autostore and pick up a trunk light assembly. Then just tap that into the trunk wire that tells you the trunk is open. Make sure its on a fuse (probably 10 or 15amp) and when the trunk opens the light turns on.
You could also use a dome light im pretty sure.
Re: Is there a HOW TO on EK trunk light??????????????? (Ajax)
How ******* hard is it to search.
I typed "trunk light" into the search and the VERY FIRST result I got back was a write up with photos on how to put a trunk light in an EK.
https://honda-tech.com/zerothread?id=615442
x infinity
x infinity
anstitute
03-17-2011 08:00 PM
ek4d00r
08-05-2005 12:30 PM
PotatoePAPA
07-06-2004 10:08 PM
