b18c into eg
Old 07-25-2004, 12:44 PM
untitledsn41's Avatar
Default b18c into eg
i have a 95 jdm b18c for my 92 eg and i looked at the harness and it was all criss crossed. what do i need to do to correct this?? do i simply just remove the black protectant and bring the wires to where they need to be, or do i need to use the old wiring harness and just add the wires...?
oh i searched and all i could find was a obd2 gsr going into a eg so i couldnt get all my questions answerd
Modified by untitledsn41 at 10:18 PM 7/25/2004
untitledsn41 is offline
Old 07-25-2004, 01:18 PM
Default Re: b18c into eg (untitledsn41)
bump
Old 07-25-2004, 01:20 PM
TSPeed Factory
AzntaggeR's Avatar
could it be that your motor originally came out of a RHD? meaning all the wires might be backwards.
AzntaggeR is offline
Old 07-25-2004, 01:27 PM
THE94GSR's Avatar
you cant use a jdm harness in your car you need a usdm wire harness
THE94GSR is offline
Old 07-25-2004, 01:30 PM
well it looks as if all the plugs are the same just they are on opposite sides. so i need to use my wiring harness off of my 1.5 and add the vtec and knock sensor wires...?! you sure i cant use the jdm harness?
Old 07-25-2004, 02:03 PM
bump for some help
Old 07-25-2004, 02:23 PM
c'mon....anyone?
Old 07-25-2004, 02:25 PM
TSPeed Factory
AzntaggeR's Avatar
Default Re: (untitledsn41)
yeah i'm guessin you would use your old harness and add all the wires. it's a lot easier then having to hack up the JDM harness and extending everything.
Old 07-25-2004, 03:09 PM
95sihb's Avatar
I'm sure if you read this , you may find your answer, https://honda-tech.com/zerothread?id=878010
95sihb is offline
Old 07-25-2004, 03:10 PM
THE94GSR's Avatar
you can't use the jdm wire harness. just use your stock harness and cut the v-tec wires and plugs from the jdm harness and splice them onto your old harness
THE94GSR is offline
untitledsn41
10
11-30-2004 05:23 PM
untitledsn41
10
10-11-2004 02:32 PM
untitledsn41
08-05-2004 04:47 PM
untitledsn41
07-29-2004 06:10 PM
untitledsn41
07-29-2004 01:19 PM
Quick Reply: b18c into eg
  • Ask a Question
Question Title:
Description:
