D16y7 with Z6 head?
D16y7 with Z6 head?
well my friends brother just donated a Z6 head to me, and i was wondering if you can put the z6 head on the y7. I've heard it was possible and then i heard it wasn't. Can some one clear it up for me?
TIA.
-Jason
TIA.
-Jason
Re: D16y7 with Z6 head? (SimpleGreenMachine)
yeah you can do that, you just need to run EX ecu, your stock injectors, and posiblty a y8 intake matifold or maybe a z6 one will work (not sure if the sensors on obdI intake matifold will work on obdII). I think it should because I hear people swapping a y8 IM on z6 so it should be pretty close to bolt on and plug in play.
Re: (ABK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ABK »</TD></TR><TR><TD CLASS="quote">you prolly could use y7 dizzy, since it has the same mounting points as CX one. You will just need to fab it up to fit.</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91civicDXdude »</TD></TR><TR><TD CLASS="quote">Im running a y7/z6 with my 14B turbo. works great. </TD></TR></TABLE>
any info/detail on this?
Modified by SimpleGreenMachine at 8:25 PM 7/25/2004
Re: (SimpleGreenMachine)
it's prolly pretty much like balleycivic mini me. Just follow the instructions. You might need to use your intake matifold or better yet a z6 one. But I think all the sensors are the same except the fuel injectors just swap yours over to z6 IM. Everything else is pretty straight forward. Just hook up a vtec, and run p2p (I think that's the EX ECU).
I know this has been done numerous times just search and I guarantee you will find something.
Re: (ABK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ABK »</TD></TR><TR><TD CLASS="quote">it's prolly pretty much like balleycivic mini me. Just follow the instructions. You might need to use your intake matifold or better yet a z6 one. But I think all the sensors are the same except the fuel injectors just swap yours over to z6 IM. Everything else is pretty straight forward. Just hook up a vtec, and run p2p (I think that's the EX ECU).
I know this has been done numerous times just search and I guarantee you will find something.</TD></TR></TABLE>
the head is a Z6....
its d series jay..everything fits if you need parts..i plan on getting a new IM for my car, hit me up and when i come home in sept. ill give you my old one..that is if i have my new one by then....the only thing im unsure of is the 5 degrees of timing that people have issues with the z6 head on the y8 block..good luck with the mini-me
Re: (2thousandcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2thousandcivic »</TD></TR><TR><TD CLASS="quote">its d series jay..everything fits if you need parts..i plan on getting a new IM for my car, hit me up and when i come home in sept. ill give you my old one..that is if i have my new one by then....the only thing im unsure of is the 5 degrees of timing that people have issues with the z6 head on the y8 block..good luck with the mini-me</TD></TR></TABLE>
what he said its all the same!
come home and help me
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2thousandcivic »</TD></TR><TR><TD CLASS="quote">.the only thing im unsure of is the 5 degrees of timing that people have issues with the z6 head on the y8 block..good luck with the mini-me</TD></TR></TABLE>
could you explain more on this? i just pu a z6 head on a y7 block. at first it was fast. then i had to readjust the timing belt (major looseness) and i moved the camgear =[ and now my car is slower... =[
R3X5150
14
05-14-2013 01:12 AM
dohdoh420
23
10-20-2005 05:56 PM
